how to stop all this wheel hop!?
RE: how to stop all this wheel hop!?
Control arms will help that . Tires also will help if you still have the stock tires they don't grip.
And later on you could install gears for better launches. Good Luck,
Matt
Matt
ORIGINAL: fastmustangs1
Matt
Matt
your stock upper & lower control arms will flex under a high load, and so will your chassis. This flexing can cause wheel hop and will absorb some of the power your car's making instead of putting it to the ground.
ORIGINAL: mdvaldosta
ORIGINAL: DILO2001GT
what do you mean built with out a frame?
aftermarket rear upper and lower control arms, like HPM ones or Southside Machine, will help plant the rear tires much better than the stock suspension will and a pinion snubber will also help eliminate the wheel hop too.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
