5.0 stahls at idle....
a friend of mine has a 90 5.0 and since he put the e303 cam in it, it seems to stahl at stop lights every now and then...i hada car with the b camand i drilled a specific size hole in the throttle body to stop the stahlingbut i can't remember what size...has anyone ever had experienced with this???
RE: 5.0 stahls at idle....
I'm kinda new to the stang crowd so i'm not aware e303 cam. But i'm assuming it's not to mild of a cam, if so the cam shouldn't be at fault for the stalling. First I'd make sure there isn't any vacuum leaks after the install, or even bad timing..does it midfire?? Also clean up your M.A.F sensor and I.A.C sensor, then disconnect the battery terminals and touch them together..thus resetting adaptations..connect battery terminals. Now the car might stall after the reset..sometimes you need to let the car idle for 5mins..and sometimes you need to drive it, i've also noticed that you can just leave the ignition at position #2(not running) again for about 5mins..then off you are with a perfect idle.
Hope this helps..
Hope this helps..
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
