91 Ford Mustang Fuse Block
I have a 91 Mustang 5.0 and it did not come with an owners manual so I do not have a diagram of the fuse block. My wipers stopped working today so I was going to replace the fuse first before checking the motor and switch, but I do not know the # of the fuse in the fuse block. I have searched online and think I found the right one but if someone has a 87-93(I'm assuming fuse blocks are similar) could you tell me what number the fuse is and what amp fuse it is.
What I found online is that it is one of the bigger ones possibly the OJA 8.25amp. Let me know if I am close on this one...all of the smaller fuses are good I checked all that you could see through. So I am assuming it is one of the 2 metal ones that you cannot see through. HELP A MAN OUT. Thanks
RE: 91 Ford Mustang Fuse Block
check out this pic from my '88 shop manual of the fuse panel and see if this don't help you out there magicman. and welcome to the forums too. click or double click on it and it will get large enough to read it. according to the legend, it's an 8.25 amp circuit breaker which you should be able to reset and get them working again unless there's a dead short somewhere which keeps tripping the breaker.
[IMG]local://upfiles/5542/A9C3FFCD27134119B22779A9F9B1EB3A.jpg[/IMG]
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
08-10-2015 01:44 PM
