Can someone run a carfax for me? I've been cheated by a dealer!
Is there anyone on here that is willing to run a car fax for me? I bought my GT in late feb from gus machdo ford and was lied too! They told me my car had never been crashed and even gave me a report. Now I went this morning to World Ford for a tranny leak and was told that my drivers fender and door have been replaced and my frame might be bent!!!! I'm ****! they might not cover my warranty now because of this. I have to find out because i will be returning this car if so!
Vin Number:
1FAFP42X34F220703
Bought with 28.5k and i have 30k now!
Vin Number:
1FAFP42X34F220703
RE: Can someone run a carfax for me? I've been cheated by a dealer!
They had given me a clean report and even inspected the car for me to give me the 75k extended warranty, now I never noticed the door was missing the VIN stick and decals but that's something they would know about!
First they sell me a car with blem tires (which didn't bother me i was going with 315's) now this! This car was owned by the finance guy at the dealer ship and i even spoke with him before hand. HE stated no crashes yaddy yaddy....
Now The car is at the dealer (world ford) getting inspected hopefully it was minor damage and will not effect my warranty on my tranny. but if so what can i do about it?
TIA
Frank
TIA
Frank
That's the problem with Carfax.You only get info that's been reported.I looked at a Camaro that had obvious damage history and the dealer told me the Carfax report was clean.He even offered to show me the report.I declined and walked away,never to return.
If the report you get from here shows no damage history,you might have a case IF you can show evidence of damage to the dealer who sold you the car.It has been awhile since you bought the car and since you haven't had problems with the alignment you might be stuck.read "screwed".
The warranty covering the transmission should not be effected by damage to the door,fender,and frame.
Things like this can be avoided altogether if you look for mismatched VIN tags on fenders,doors,hoods,etc.Improper fitting parts with varying gaps between doors,hoods,and fenders are also a good indicator of damage.Overspray on any part of the car (even underneath) is a dead giveaway.
I normally ask for an "Oasis" search from Ford, through a dealer service department. (Not necessarily the dealer I want to buy the car from).
My local Ford dealer does this for me whenever I wanted to buy an "Off Lease" Continental.
OASIS RESULT:
1FAFP42X34F220703
06/27/2007
19:37:33
FCXWS447
©Copyright 2002-2007 Ford Motor Company. All rights reserved.
// for our friends in vrep
var strVehDesc = "2004 MUSTANG";
function getVehDesc()
{ return strVehDesc; }
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 MUSTANG
BODY STYLE
2 DOOR COUPE GT
ENGINE
4.6L EFI SOHC
TRANSMISSION
T3650 5-SPEED MANUAL
AXLE CODE
LE
ENGINE CALIBRATION
4ZE2GT0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09 [/b]
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/05/2004
BUILD DATE
03/23/2004
SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0876 - USA 2006 72/75,000 CPO POWERTRAINCARE WARRANTY
STANDARD DEDUCTIBLE:100
OWNER NAME:CERTIFIED CUSTOMER
OPTIONS:
EXPIRATION DATE:11/05/2010
DISTANCE:75,000
RENTAL:28 UP TO 5 DAYS
TOWING:0
CONTRACT SOLD BY:USA04931
ESP CONTRACT START DATE: 11/05/2004
WARRANTY REPAIR HISTORY
[hr]
12/19/2006
DEALER:Gus Machado Ford, Inc.
WARRANTY CLAIM NUMBER:328088
ODOMETER:027625M
PART NUMBER
PART DESCRIPTION
QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC3R3Z 7124AD
SYNCHRONIZER ASY
001
7003A
103104
DOES NOT OPERATE PROPERLY
XT 2QDX
MOTORCRAFT BATTERY
006
7003AZJ
TA 29
MOTORCRAFT BATTERY
001
7003A2
000
ADD
27630 THIRD GEAR SYNCRO AND GEAR. 7003A,7003AZJ,7003AZ 630 TEST DROVE VEHICL E AND FOUND IT GRINDING IN SECOND LIGHTLY,BUT MORE WHEN SHIFFTING INTO THIR D GEAR.REMOVED TRANY AND BENCHMOUNTED TO DISASSEMBLE FOUND WORN SYNCRO AND GEARS TEETH ON BOTH THIRD AND SECOND.REPLACED PARTS AS NEEDED TO COMPLETE T HE REPAIR.REASSEMBLED AND INSTALLED TO TEST DRIVE FOUND ALL CONCERNS ELIMIN
Click Here for Full Warranty History
//strVRDesc = "2004+MUSTANG";
END OF OASIS REPORT FOR1FAFP42X34F220703
function SetCookie( name, value )
var DEFAULT_DAY = "Monday, 01-Jan-2020 07:00:00 GMT";
var DEFAULT_DOMAIN = ".fordtechservice.dealerconnection.com";
var DEFAULT_PATH = "/";
var tmp_cookie = name + "=" + escape(value);
tmp_cookie += "; PATH=" + DEFAULT_PATH;
tmp_cookie += "; DOMAIN=" + DEFAULT_DOMAIN;
tmp_cookie += "; EXPIRES=" + DEFAULT_DAY;
document.cookie = tmp_cookie;
SetCookie("preVins", "1FAFP42X34F220703,1FAFP45X83F320239,");
SetCookie("VinDetails", "1FAFP42X34F220703_year:2004|1FAFP42X34F220703_mod el:MUSTANG|1FAFP42X34F220703_symp:|1FAFP42X34F2207 03_cid:|1FAFP45X83F320239_year:2003|1FAFP45X83F320 239_model:MUSTANG|1FAFP45X83F320239_symp:490000,40 4000,607600,614600,|1FAFP45X83F320239_cid:*200 232 104*|");
window.open("http://WWW.fordtechservice.dealerconnection.com/vdirs/protech/refreshVin.asp?from=oasis", "refreshprev")
Looks like they already had the transmission out before for a syncro concern
//alert("www http://www.fordtechservice.dealerconnection.com")
document.oasisresult.submit();
//document.body.style.cursor='auto'
Wow Thanks! That's what I really needed, I was just called (Few hours ago) And they stated it seemed the cars tranny was worked on before but they never stated it was with the dealer for a factory warranty repair.
