Gear, RPM, AND Redline Speed Calculator Spreadsheet - MODS MAKE STICKY
This is a nifty little spreadsheet to see what a gear change would do to your RPMs. All you do is put in your tire and rim size, change the ratios for your transmission and rear end, and then put the speed you want to see the RPM change at. Also, there's a section at the bottom to calculate the redline MPH for each gear you're in. This spreadsheet was made by rmr1923 and I thought it was quite helpful, so I figured I'd share it for everyone else to use. I will embed a screen capture of the spreadsheet so you can see how it looks before you download it. ENJOY!
*MODS SHOULD MAKE THIS A STICKY*
Here's a link for download:
http://www.mediafire.com/?f6t3nnp1z9c
[IMG]local://upfiles/73142/AB67F8FFBA6C43F690C851B9D111ECA4.jpg[/IMG]
RE: Gear, RPM, AND Redline Speed Calculator Spreadsheet - MODS MAKE STICKY
Well, alright. Didn't know who did or did not do this already. I have only been looking at changing gears for a few days now... pardon my "ignorance" on this topic... Plus this one wasn't over done. It was a quick and simple look at how much a gear change can generally differentiate your RPMs...
ShaneB26154
35
03-04-2021 04:05 AM
inyadreems
08-21-2015 09:10 AM
calc, calculator, end, gear, line, make, mustang, red, redline, regear, rpm, speed, spreadsheet, tire, transmissionrear
