Aod to T-5 swap parts lists
RE: Aod to T-5 swap parts lists
youll need the tranny pedal assembly t5 bell housing andwiring harness fly wheel and clutch 10.5inch clutch cable i heard a double hump cross member will be needed for h pipe clearence but the one i had for the auto works fine.. mounts and driveshaft are interchangable.. you can by pass the safty neutral switch instead of buyin the wiring harness but i don;t think you will have reverse lights
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
