What power can DFX Centerforces take?
RE: What power can DFX Centerforces take?
From Jegs web site
Centerforce's DFX series is engineered for competition standards of quality and craftsmanship. The DFX series is aimed at high-end applications that continually demand increased integrity and holding-capacity. DFX scores big, not only with holding-capacity and strength, but also provides some of the best drivability from a race-inspired clutch. DFX retains an easy pedal effort, thanks to Centerforce's patented ball bearing actuated diaphragm, for smooth engagements without detriment to the vehicle's release components. The Centerforce DFX performance clutch system utilizes Nodular Iron pressure plate rings and reinforcements designed to help prevent drive strap breakage and safety. The DFX series allows the end user to tailor the performance and style of driving with different choices of clutches and clutch discs: From street/strip to full-on drag racing capability.
From Ceterforce' web site
The DFX line is the latest series of performance clutches from Centerforce. Centerforce is proud to announce DFX as their competition-proven clutch package for select import and domestic applications. This new DFX series is engineered for competition standards of quality and craftsmanship. The DFX series is aimed at high-end applications that continually demand increased integrity and holding-capacity. DFX scores big, not only with holding-capacity and strength, but also provides some of the best drivability from a race-inspired clutch. DFX retains an easy pedal effort, thanks to Centerforce’s patented ball bearing actuated diaphragm, for smooth engagements without detriment to the vehicle’s release components. The Centerforce DFX performance clutch system utilizes Nodular Iron pressure plate rings and reinforcements designed to help prevent drive strap breakage and safety. The DFX series allows the end user to tailor the performance and style of driving with different choices of clutches and clutch discs: From street/strip to full-on drag racing capability.
I was looking into them this week. Lil to pricey for me. I'm goin' w/ the dual friction instead. They will handle the power you're making.
Dual friction.......... Jegs site
Up to 90% Increase in Holding Capacity Compared to Stock
These clutch sets, which include a pressure plate and disc, are designed for high-horsepower, high-torque output engines. They're also great for radically-altered street and four-wheel drive with tall tires vehicles
well i have the chance to get one for 200bux with my transmission iam buying on friday, so if its a good clutch i will go ahead and buy that. if not then i will need a place to buy a 26 spline clutch somewhere. to work with the type of power i have.
so do you think this DFX is good enough? if it is then i guess i'll just get this one as well.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
09-25-2015 06:58 PM
