NO SWAY BAR????OKAY????????
wondering if i can take my front sway bar off my car. IVe got a full suspension 90/10s 50/50's drag springs and sub frames also ive got a 2800 stall and a 351W with bolt ons will it casue any damage if i run no sway bars??????????????????????????
RE: NO SWAY BAR????OKAY????????
no swaybar is a supremelybad idea. if you have no sway bar your handling will suck. your car will float around turns like an old buick. i had a broken swaybar mount and took it out for a week. the first time i got on the highway and got into a race i had to make a lane change at about 70 and it felt like my car was going to loose control. a week later i got this fix and it is much better. i wouldn't reccomend this to any one. expecially if you make high speed lane changes. also why did you want to take it out in the first place????????
There will be no damage to the car. Running without the sway bar will allow the 90/10 front shocks to actually do their job and allow the front to rise, transferring the weight to the rear.
Handling will be worse, but not detrimental.
09-16-2015 07:53 PM
