New mustang owner
RE: New mustang owner
Yes you will need to beef up the T-5. You can get a stronger gear set from astro performance but still leaves you with the weak caseor you can upgrade to a tremec transmission it all depends on how deep your pockets are and what you plan powerwise for the car. Like blue oval boy said their only rated at 300-330lb ft of torque so their pretty easy to break
ORIGINAL: blueovalboy7
Well I did a little research and a site I found said that generally a stock T-5 is rated to handle about 300 lb. ft of torque, so I'm pretty sure if you build that motor up you'll need to built up your tranny as well.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
