Mustang is fvcked!
RE: Mustang is fvcked!
ORIGINAL: grabbem88
flywheel bolts?came loose....pilot bearing? my clutch blew out in pieces on my 98gt it made a loud boom......then it was clang!clang!
pilot bearing would.....i only had a shell when i pulled the tranny...input shaft was shaved...is it coming from the bottom right?
checked your oil lately? hope you didn't spun a bearing!!
ORIGINAL: grabbem88
Wow, bro. Sounds like you messed up youre Stang. Sounds like a backfire, are you leaking gas into the intake manifold? Also check youre oil, make sure there is no coolant in it. I wish i could hear it, it would be much easier.
ORIGINAL: Casper98GT
