Speedcal/Programmer
RE: Speedcal/Programmer
I just got the prediator tunner and really like it, I wold suggest that you get a programmer vs. the speedcal the programmer can do a lot of other things for you (timeing, a/f ratio ect.) so for the money that is where i would spend it. IMO
can you change each particular setting individually or do you have to load a whole tune? What I mean is can I just adjust the timing by itself, and the next day adjust the shift points etc...
here are all the things that you can change with the predator, I loaded the performance program in it on Mon. and tonight i am planning on going home and changing my shift points and pressure in mt trans to make it a firmer shift. So i guess the answer to you question is yes and no, you have to load the whole program, but you can modify things in that program to your likeing at a latter date if you like. If i am wrong on this someone else correct me but this is what i am doing with my shift points and pressure tonight.
Diablosport Predator Performance Tunes Re-Map:
ยท Fuel Curves
ยท Timing Curves
ยท Extend Speed Limiters
ยท Extend Rev Limiters
Diablosport Predator allows the end user to make the following fine tuning adjustments:
ยท Timing Table (+/- 10%)
ยท Fuel Table (+/- 15%)
ยท Idle (+/- 20%)
ยท On/Off switch for Traction Control/Rear 02 Sensors (Off-road Exh)
ยท Speed Limiter
ยท Rev Limiter
ยท Part and Full Throttle Shift Points
ยท Shift Timing
ยท Shift Pressure
ยท Re-Calibrate Speedometer for Gear and Tire Size Changes
DiabloSport Performance tunes require the use of Super Unleaded/ Premium grade fuel only, Amoco, Sunoco or Mobil if possible.
ยท Fuel Curves
ยท Timing Curves
ยท Idle (+/- 20%)
ยท Speed Limiter
ยท Rev Limiter
ยท Shift Timing
ยท Shift Pressure
ORIGINAL: 00Stang
Thanks DIVER, I'm starting to read all that fun stuff at their website. How does the predator compare to SCT? Anyone know?
