got my new slicks tonight!!
RE: got my new slicks tonight!!
I would recommend you get the tubes, see this for the tube part numbers. http://www.mickeythompsontires.com/strip.html
This board agrees with the tire manufacturer. Hmmm.... I wonder who is right, the people who make the tires or the other board on the internet.
They also sell tubeless ones, but if you bought the ones that you are supposed to have tubes for, you should get tubes
Yeah, I know but I asked if I MUST use the tubes. There were several other people on the other board that run the same exact slicls as I do without tubes and without problems.
Between both boards, it's like 50/50 for yes and no.
It's not a question of who's right or who's wrong, it a question of if it's manditory or not.
Apparently, I guess, it's ok to run without them....which is all I wanted to know.
short answer... no
you dont need tubes really unless you run rim screws, I've got the same tires and I don't run tubes or screws. now it may be recommended to do so, but needing to and recommending are different things.
well I would be safe and do it.....give this some thought.....a flat tire at 100 mph... not a slow leak ..like a blow out is what happens if the bread break..you can run them with no tube though.....also you don't need the screws for street stuff but should be used at the track to keep the tire from spinning on the rim
BeatnikFink
10-01-2015 08:00 PM
Dragonus18
09-09-2015 01:21 AM
