Antifreeze?
Does anyone have a prefrance on antifreeze? I just put that permacool in my car and it seems to be running on the warmer side of normal? anyone else think its weird? I put it in this afternoon and and started it up ran it and it went to about 5 degrees warmer than norm... what temp is everyone tryin to be at anyways!
Thanks |
RE: Antifreeze?
I would only use Motorcraft or what the dealership suggests
RE: Antifreeze?
The temperature attempts to be at the setting
of the thermostat that you have in. You probably have a small air bubble in the cooling system. If it does not work it's way out in a few days, you may have to use the fixes usually discussed. |
