dallas mustang speedo calibrator
While inspecting a couple curious items in my new to me 2001 mustang GT i noticed a steeda short shifter as well as a dallas mustang speedometer calibrator. it also has aftermarket guage faces, beyond this i dont know what this car has, or doesnt have in the way of aftermarket, I've had the car less than 10 hours. my question is, has anybody ever used one of these to recalibrate for new gauge faces???
thanks.
-kevin
thanks.
-kevin
RE: dallas mustang speedo calibrator
Hmmm.... This is interesting. so, its probably more likely that i have gears than just using it to compensate for a new speedo? well whats a good way to tell if the car has different gears in it?
i know the trans is a little louder than i thought it should be, but no grinding, it almost sounds like the heater is running... i am very new to mustang ownership, but not new to cars.... please bear with me while i learn more about the car.
thanks guys
-kevin
thanks guys
-kevin
jack up the rear end and turn the driveshaft by hand while watching the rear wheel make 1 full revolution. count the turns on the driveshaft it takes to make the wheel go 1 turn and this will tell you the approx. gear ratio. 4+ turns = 4.10 gear; 3-3/4 turns = 3.73 gear; 3+ turns = 3.08 gear, etc etc.
not hard at all, just make sure both rear wheels are off the ground on good jackstands and that the trans is in neutral and the parking brake is off. put some chalk marks on both the wheel and the driveshaft for reference marks so you can count the turns and you will be able to do it no sweat.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
