Some questions about Clevors, which 351W work?
Heya everyone, I have a question about something I have been thinking about doing for my car.
I have a 1998 351W that I would like to turn into a Clevor but I have no clue if I can use 351C 4V heads on it like you can in the late 60's and 70's 351W's I am also aware of the special intake adapter needed, though I have heard of people just dropping a cleveland intake on and it working ~shrugs~ I have found a whole kit online to make a Clevor but this is what is holding me up.
My last question is if I cant turn the 98' block into a Clevor then how close is it to the 95' Cobra R Windsor? Is it the same block? What can I do with this block? What changes to the wiring harness would I have to make and the ECU?
Thanks guys
Sincerely Eric
Thanks guys
Sincerely Eric
RE: Some questions about Clevors, which 351W work?
Why not just put on a good set of aftermarket aluminum high performance windsor heads. Results will be as good if not better and no hastle with adapters and making things fit. JMO
Hmm, do you have a few names in mind? Who makes them and which are the best? I also still interested in the Cleveland head swap too.
Hmmm, i hope so because I would still like to run a Clevor in my mustang just because its a little different and of course for the insane flow of the 4V heads STOCK its even crazier when they are bench flowed! I have a few ideas for the induction on the car. There is a SWEET fuel injection system in Australia called UltraFlow EFI manifold It made 390hp and 405ft-lbs on a 351C 2Vaussie w/ 8:1 comp Impressive. I would like to find out more about it but its kinda hard to find information on it.
The guy that owns The Mustang depot says that all windsor blocks will work with his Clevor stroker kit and all Cleveland heads will work. Anybody have any other info on it?
HIS S-197
08-10-2015 05:47 PM
