Sponsored by:
Sponsored by: DashLynx
throwout bearing welded to input shaft
Old 12-22-2007, 08:56 PM
machnone
machnone's Avatar
Default throwout bearing welded to input shaft
Yankin the tranny out of a 98 mustang to change the clutch and i think the throwout bearing is welded to the input shaft. The tranny wont come out of thge bellhousing. Looks like i will have to take the belhousing off at the same time. I'm pretty sure the shifter fork goes all the way around the throwout bearing, so it has to stay in. This project has proved to be more than a pain in the ****. Anyway to save the tranny if that is the case? Or will i need a new input shaft? or tranny itself? I will know more tommorrow once i finally get it out of the car. It was squealing so loud, i was afraid of this being the case.
machnone is offline
Old 12-23-2007, 07:30 AM
99_GT
99_GT's Avatar
Default RE: throwout bearing welded to input shaft
If it damaged the shaft, i would say you need a new one.
99_GT is offline
Old 12-23-2007, 09:09 PM
1991LX5.0
1991LX5.0's Avatar
That cant be, the TO bearing needs to move on the input shaft to engage and disengage the clutch. have someone push the clutch in while you look in there you should see the TO bearing sliding on the input shaft
1991LX5.0 is offline
Old 12-23-2007, 09:26 PM
FrostByte
FrostByte's Avatar
FrostByte is offline
Old 12-23-2007, 09:39 PM
chevykilla93
chevykilla93's Avatar
Were youshifting that thing? The TO cant be welded to the input it has to move. If it really is welded you would just need a new input as long as you havent done any damage to the rest of thetranny.
chevykilla93 is offline
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: throwout bearing welded to input shaft
