I have a cracked intake manifold, what should i do?
RE: I have a cracked intake manifold, what should i do?
Yes, 1999-2004 manifolds are all compatible, as PI manifolds. You can do a manifold swap yourself--As a matter of fact, I just swapped my own manifold for that very same reason: cracked at the temp housing, and leaking coolant. The solution is to get a manifold with the aluminum crossover. You can get a new manifold for about $250 off of eBay. I have the entire process in pictures if you're interested. I'm attaching a picture of the new manifold I put with the aluminum crossover after I torqued it down, but obviously before I reattached fuel rail, alternator, plugs, etc. Let me know if there's any questions I can answer for you. I hope you decide to swap it yourself. It was so much fun to do this (see picture of me after I started the car with no leaks the first time)...hehehe...good luck!
[IMG]local://upfiles/12394/C8C6391CEB83488595462660AE354047.jpg[/IMG]
[IMG]local://upfiles/12394/FA8C772E95834FAF9419CE8E409B46E1.jpg[/IMG]
And even though it doesn't matter to you, with a PI setup, my manifold came from a 2003 GT, and my car is 96 GT. Even if you don't have the PI heads, the manifold will torque down with no leaks and no RTV if done carefully.
jwog666
12-27-2021 08:09 PM
