Mustang GT 5 spoke 17’’ rims
Old 12-17-2003, 01:04 AM
improved
improved's Avatar
Default Mustang GT 5 spoke 17’’ rims
Heys guys i was looking at buying a set of Mustang GT 5 spoke 17' rims...i am still a ford guy and wish to add some mustang wheels to my other car. i know the the 114.3 fits my car just that the rims are a 30 offset and mine are a 35...so i was wondering if i bought some oem Mustang GT 5 spoke 17' rims...i could just shave off the back 5mm so it will fit my car. I dont have the rims in front of me so i dont know if it is worth my time to get them. So can someone tell me if i can safely get the back of the rim(mating surface) machined. thanks</P>
matt</P>
improved is offline
Old 12-17-2003, 01:24 AM
95Stealth302
95Stealth302's Avatar
Yes, you probably can, provided that the surface is still big enough to envelope the tire treads, as well as provide a needed seal. If the part you're shaving off has some sort of lip on it, or isnt smooth, or you're going to be altering the "flushness" of the rim with the tire, then don't do it. Otherwise, a 5mm machining won't be any problem. Good luck.
95Stealth302 is offline
Old 12-17-2003, 03:00 AM
improved
improved's Avatar
Oh apologize for my bad wording<IMG src=smileys/smiley6.gif border="0"> but i meant the where the actual wheel connects to where the studs are...so the offest would be alright...its a bummer without have the wheel in front of me but i figure mustang guys have mustang rims so they could possible check it out for me.</P>
<IMG src=smileys/smiley17.gif border="0"></P>
tDoes this make better sense.<IMG src=smileys/smiley5.gif border="0"></P>
improved is offline
Old 12-17-2003, 04:10 AM
improved
improved's Avatar
Did moderator move this.</P>
Hummm....this has nothing to do with me looking for rims.<IMG src=smileys/smiley5.gif border="0"></P>
</P>
please move back thanks</P>
</P><edited><editID>improved</editID><editDate>37972.0922106481</editDate></edited>
improved is offline
Old 12-17-2003, 12:25 PM
95Stealth302
So the place where the axel spindels connect to the actual rim? That shouldnt be a problem either, as long as everything fits flushly, and tightly.
Old 12-17-2003, 03:43 PM
improved
improved's Avatar
yeah they will fit but i can't tell if 5mm will cut so far as to have the correct size hole for the lugs. i wonder it there is enough meat.
improved is offline
Urambo Tauro
12-17-2016 03:30 PM
Jwoolsey08
10-02-2015 08:42 AM
Goldenpony
08-19-2015 08:46 PM
Mr. D
08-17-2015 09:53 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Mustang GT 5 spoke 17’’ rims
