Oil capacity
OK i've checked online with four sites and they all say a different thing when it come to amount of oil for my 302. I even called auto zone and there not even close. My range that i've came across is 4 all the way to 8 quarts to change the oil. So I ask what is the correct amount of oil needed when changing the oil
RE: Oil capacity
a stock pan should hold 5 then i would double check it
RE: Oil capacity
5 qts with filter change.
RE: Oil capacity
5 qts. what idiot told you 8?
RE: Oil capacity
Only way it can be higher than 5 is if there is a big oil cooler and remote oilfilter that is way bigger than the stock on for a 302.
RE: Oil capacity
Advanced Auto told me 8. I replied your outta your f!?kin mind. I done 5 but for some reason my check oil light is on now. I am running Royal Purple now no that it should make a difference
ORIGINAL: OnyxCobra 5 qts with filter change. |
RE: Oil capacity
it's definitely 5 qts mang:)
RE: Oil capacity
After you shut off a warm engine pull the stick and it should read full.
RE: Oil capacity
ORIGINAL: Jfsram After you shut off a warm engine pull the stick and it should read full. |
RE: Oil capacity
5 qts with oil filter change. I promise you.
