Any 1.5L Kenne Bells out there?
RE: Any 1.5L Kenne Bells out there?
ORIGINAL: Dbeck002
Just want to know if they whine as loud as the 2.2L... I remember someone on the board had one, forgot who though.
They make 2.2L for our 5.0? Where can I find them?
Yes but you will make a lot better numbers with the relativly low cost of the Flowzilla inlet upgrade.
EDIT: The Flowzilla upgrade isnt just an Inlet. It also has an integral bypass and accepts up to a 90mm throttle body. The standard only accepts a 70mm and must utilize an external bypass. The Standard is only rated for 300 RWHP with no HP loss due to restriction. The Flowzilla can flow at over 50% more capacity than that of the standard.
Blowzilla/Flowzilla - $3699.00
Blowzilla/Standard - $3399.00
Well, your right about it not being cheap. Thats why I made sure to say "relativly" LOL. If you run that 2.2 Dbeck, your car is gonna make your nuts pop out your butthole! That would be a wild ride.
