How to access headlights on 94 mustang? (pics)
I searched google and AmericanMuscle.com for a guide that would say how to take off the radiator? cover that sits over the headlights on the sn95 mustangs.
Being that I could not find a guide, I feel like i'm being stupid and it should be a really easy job. Anyways, here are some pics so I can show you what I'm talking about. How do I get these things off of there?
Thank you!
Thank you!
RE: How to access headlights on 94 mustang? (pics)
Those are fairly simple. The ones with screw heads, hold the washer part and unscrew. Then the washer piece will pull out. It's smilar to an anchor bolt that swells when the screw is put in. The ones with the flat tops, just pull them with a pair of diag cutters.
unscrew the first pic.
the second ones just pull up on the center.
btw...for the headlights you only need to deal with the first and second pic as those are like flaps that pull up. in other words, you dont need to remove the whole cover.
ORIGINAL: CheesyBeef
Thank you both. For some reason when I unscrew the screw in the first pic it does not come up even when I try to lift it with a screw driver?
you cant put any pressure on it when you unscrew it. the threads are almost microscopic so if you push down at all then the threads wont grip. just put the screwdriver in there far enough to turn the screw, and you have to lift the screwdriver while turning.
