MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   General Tech (https://mustangforums.com/forum/general-tech-6/)
-   -   i'm not sure where to post this (https://mustangforums.com/forum/general-tech/467581-im-not-sure-where-to-post-this.html)
Grmrefer Jul 25, 2008 08:49 AM
I Just bought my 1st mustang and i need some advice
It is a 1996 base with no mods
3.8
5 spd
i found an engine YearOne Power Crate 400hp 351W crate engine (i will post the engine specs below)
what i need to know is there anything i need to know before i order this.
Or is there any advise from someone that has tried something like this.
Engine Specifications:
·Horsepower- 400+
·Torque- 415+ ft/lbs
·Compression ratio- 10.0:1
·Dyno-tested: Yes, includes harmonic balancer & flexplate
·Dyno sheet: Included with engine's output
·Vacuum produced: 12hg @ 800RPM
·Recommended fuel- 92 octane
·Max recommended RPM- 6000
·Block- 2-bolt iron
·Crankshaft- Cast iron
·Pistons- Hypereutectic
·Connecting rods- Stock reconditioned
·Camshaft- Hydraulic roller
·Valve lift:.571 int .574 exh"
·Duration @ .050" (int/exh): 218deg/224deg
·Rocker arms- 1.5:1 ratio
·Cylinder heads- Aluminum
·Valves- Stainless steel 2.02 int/1.60 exh
·Valve springs: Heavy duty
·Bore x Stroke- 4.030" x 3.50"
·Intake manifold- Dual-plane aluminum
·Oil pan, timing cover, valve covers included
·Engine fasteners: High tensile strength
·Warranty- 12mth/12000mi
ryan1994mustang Jul 25, 2008 10:07 AM
RE: i'm not sure where to post this
you are going to have to change alot out in that car to handle that motor. rear end, transmission, computer, suspension, and probably a new fuel system. and that is just the beginning. there is alot that goes into an engine swap from a 3.8 to a 351. its gonna cost alot of $$ to do it right
BigGameHunter589 Jul 25, 2008 10:27 AM
Thats going to be a ton of work dude.. Make sure you have the time and thousands of dollars and maybe a garage to do all your work in. Engine swaps are insanely time consuming
GreyStang Jul 25, 2008 10:52 AM
Are you doing the swap yourself? Ever done something as involved as this before??
Grmrefer Jul 25, 2008 12:25 PM
yes i was going to try to do this my self but after reading this maybe not
does anyone have any ideas what i should do
my main aim is to show up my friends that swear that honda is GOD
i want mussel not some souped up grandma car
any ideas will be welcome
thx
ryan1994mustang Jul 25, 2008 12:48 PM
believe it or not, you can get some pretty good power out of that v6. there are a couple of guys on here running forced induction sixxers and are putting out awesome numbers.
GreyStang Jul 25, 2008 01:27 PM
ORIGINAL: Grmrefer
thx
Honestly your most cost effective choice is to sell the V6 & buy a GT. It'll cost you a FORTUNE to swap engines if you have to pay a garage to do it for you.
Adding forced induction to your V6 is a good idea too,, will cost youaround $5000 once it is all done. What's your budget? :eek:
BigGameHunter589 Jul 25, 2008 01:30 PM
Start with a cold air intake and a custom exhaust.. just that'll probably take care of those silly ricers as long as they arent running turbos or have alot of stickers.. dude stickers addlike 10whp. j/kI share your passion for making ricers pay by eating American dust.
945LSTANG Jul 25, 2008 02:14 PM
ORIGINAL: Grmrefer
3.8
5 spd
·Horsepower- 400+
·Block- 2-bolt iron
all of that for how much?
Grmrefer Jul 25, 2008 02:49 PM
im looking to spend about 15000 the engine i posted is at year one for about 4300
i do have a buddy with a lift and any tool i would need at his house so i would be doing most of the work with him (one the only friends i have that is not in a honda)
© 2026 MH Sub I, LLC dba Internet Brands
