This is the 2nd oil change I have done on the car. After the first one, everything was fine. Just to clarify...it is a slight ticking/knocking sound at idle, but once the rpms rise it goes away. Im no expert, but if something was bent wouldnt the noise get worse with higher rpms?
the filter has nothing to do with it. it is either a valve or the vescosity of the oil is too low did you put 5w 30 in it like it recamends?
No offense to you UTI guy... But it could be a crappy filter which is restrictive. Either way it was a quesiton I asked the OP not you so please lay off a bit, thank you!
