Caliper mounting bolts wont tighten to specs
Old 11-17-2008, 09:52 AM
stevenn1
stevenn1's Avatar
Question Caliper mounting bolts wont tighten to specs
I replaced the front stock brake pads with ceramic ones. Went to tighten caliper bolts (that go into slide pins) to 23 ft lbs (per the Haynes manual, which seems kind of low torque to me) and before i get the torque wrench to click, the pin starts to turn which wont let the bolt reach the specified torque. Now what?
2002 GT
stevenn1 is offline
Old 11-17-2008, 02:16 PM
stevenn1
stevenn1's Avatar
After I talked to a guy at an auto parts store, I got to looking at it a little closer. The end of the slide pin (where the small bolt goes) does have 2 flat edges on it - they are on opposite sides of each other, and the rest of it is rounded. So I put an open end wrench (16mm) on the slide pin & a socket (12mm) on the bolt with a small 3/8" drive torque wrench and tightened it.
stevenn1 is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Caliper mounting bolts wont tighten to specs
