MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   General Tech (https://mustangforums.com/forum/general-tech-6/)
-   -   won't start when hot (https://mustangforums.com/forum/general-tech/505371-wont-start-when-hot.html)
dnm557887 Dec 20, 2008 10:14 AM
97 mustang starts good cold, won't start when warmed up. have to wait 20 minutes before it will start.
Chopper Dec 20, 2008 05:55 PM
Need more info.
Won't crank?
Cranks but no start?
Starter engages the flywheel but the crank won't turn.
If the last one is the condition it's probably a weak battery,dying starter,or poor ground.One reason is the starter motor has higher resistance in the windings when it's hot.This raises the voltage required to turn the engine with the starter.Poor grounds,a weak battery,or a bad wiring connection all cause higher resistance also.
PJC Racing Dec 22, 2008 11:39 AM
Have you been messin with the timing? Could be to far advanced.
LilRoush Dec 22, 2008 11:43 AM
Check your air filter. Dirty air filter can cause what you described.
mestit3 Dec 23, 2008 06:40 PM
coil(s)?
teal94_stang Dec 24, 2008 10:36 PM
i'm another one for the coils. coils can act up when the motor gets up to temp. just a thought.
88blk5.0 Dec 26, 2008 06:48 PM
bad starter/ starter heat soak??
© 2026 MH Sub I, LLC dba Internet Brands
