Air Inject error 0n V6
My 2000 V6 is showing the following errors. Any info on what I need to do to correct will be appreciated.
P0411 SEC Air Inject System incorrect flow P1414 SEC Air Inject Monitor Ckt high input |
You need a new pump. Very common problem. Remove the pump hoses and check to see if water comes out.
Originally Posted by WhiteFoxGT
(Post 5770704)
I pulled the same code about a month ago. I just disregarded it and reset the light everytime it came on. Last week it came on, and shut itself off before I could reset the light, and it hasn't come back on. Check the lines to the diverter valve, and check to see if the pump has water in it.
code list mustang 2000 v6
1 Attachment(s)
Many thanks also Bud!!! I had that p1414 code as well!! I found a pdf up here with the code meanings!! this should help out someone that needs it!!
