injectors (how they work)
by madman@thewheel
What is impedance?
Impedance is the electrical resistance of the electromagnetic coil inside the injector. This is measured in ohms and can be determined with an ohmmeter. Injectors are classified as either high-impedance (also known as “saturated”) or low-impedance (known as “peak and hold”). High-impedance injectors usually range from 11 to 16 ohms of impedance, while low-impedance injectors usually range from 0.7 to 5 ohms of impedance (these impedance numbers are based on what is currently available in the consumer market and are subject to change). Most OEM engine computers are designed to control high-impedance fuel injectors. Low-impedance injectors are generally preferred for racing or ultra-high performance use because they respond more quickly, but aftermarket engine controllers are usually required to control them.
What do the terms “static” and “duty cycle” mean?
An injector in an engine turns on and off very quickly to control the amount of fuel delivered. The amount of time an injector is turned on and delivering fuel is known as the duty cycle. This is measured as a percent, so 50% duty cycle indicates that the injector is held open and held closed for an equal amount of time. When the engine needs more fuel, the time that the injector stays on (its duty cycle) increases so that more fuel can flow into the engine. If an injector stays on all the time, it is said to be static (wide open, or 100% duty cycle). INJECTORS SHOULD NOT GO STATIC IN A RUNNING ENGINE! If an injector is static in a running engine (open 100% of the time), that injector is no longer able to control fuel delivery. It is just “along for the ride”. This could be an indication that the injector is too small for the needs of the engine. Injector duty cycle should usually not exceed 80% in a running engine at any time.
What is impedance?
by madman@thewheel
What is impedance?
What is impedance?
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
