cobra r wheels leak air help!
Are you high or something? Solid aluminum alloy doesn't allow air to seep out. Take a damn chemistry class.
The vast quantity of different molecules that make up "Air" are often very small, so small that they are actually able to seep through the RUBBER of a tire over time. This is why racing and many wheel shops have gone to nitrogen to fill their tires. It's a larger molecule that is less reactive to hot and cold, so pretty much whatever pressure you set it at cold, that's what it will be hot, and it won't seep through the RUBBER.
and air is only made up of 2 molecules that make up 99% of the air - 78% nitrogen and 21% oxygen with another molecule argon which is <.1% so maybe if u lost all the oxygen in ur tire you would still have 78% of an inflated tire with pure nitrogen so getting ur tires filled with pure nitrogen seems a little overboard
and you should be taking the class and ill continue to get high
Diode Dynamics
28
05-26-2022 12:02 PM
SANDY21
08-17-2015 02:41 PM
