Is there a window relay for just the driver front? or is it definitly the motor?
Is there a power window relay of some kind under the dash or is the motor definitly burned out??? only 26k miles 02 GT??? Its definitly not the switch. All the other windows work
RE: Is there a window relay for just the driver front? or is it definitly the motor?
I went to alldatadiy and there is a HUGE layout of troubleshooting windows. There is a relay, though I didn't get a chance to find it. Might be worth while to sign up to diagnose it. I started to post but it was going to be HUGE.
i am having a similar problem on my 91 gt.... switch is working but before i go pulling the motor i was wondering if there was a relay just for the drivers window on mine also...mike
I'm not sure if there is a relay but there probably is.
What I always do BEFORE I pull a window motor is to use a test light to make sure it is really getting power. If it isn't, then go backwards and check the switch and relay if anyone can say where it is located.
HorsePower99
08-26-2015 11:29 PM
