replacement hp fuel fittings,where do i get em?
RE: replacement hp fuel fittings,where do i get em?
its steel line, right? you might just want to get a new line to run between the 2 with the fitting on it. you would have to cut the line to only replace the fitting, then it would be too short so you would have to make a ghetto extension job.
no,its a nylon line with a hairpin style duckbill connector.the connector itself is broke.fitting is plastic with a barb design at the end that locks the hose on.i want to replace the connector and dont know where to find one at.do they sell these aftermarket?
u have a pic? im not sure how the stock stuff is. i started from scratch.
i think u probably can just get a new connector. one sec, ill check autozone
ohh, and thanks
ohh, and thanks
i didnt see anything on the site. the dealer would charge u up the butthole to do it. u can probably get the part from the dealer and install it urself. or just search local junkyards/parts stores for the part
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
