stock gt horsepower help
Amen.
If it's properly installed, tuned, and have all the safety features(window switch, purge valve, bottle warmer, WOT trigger, etc.) then it's perfectly safe. You'd be surprised how many Mustangs run nitrous without any major problems
Yeah but as long as you aren't going around purging in front of cops I think you'll be Ok. I don't think theres a Judge on the planet that would write a search warrant to take a look at your engine bay.
nitrous with all the supporting mods can cost like $1,600. tune and all its pretty safe an h/c/i set up would cost around the same if you scrap for the parts and its alot safer then nitrous but probably wont add an extra 100hp. the words "easiest Cheapest way" should never be used as far as power adders. cause keep in mind you get what you pay for
stop making up numbers...
The other problem with nawzzz is,, U gotta keep refilling it! And, sure enough when you need it most is when the bottle is empty
