gear install quote what all do i need to get
did some searching but just havent found quite what i was looking for.
i can get the 4.10 gears for 150
and the shop said they will install it for 175
is that a good price for the install?
i need to get the stuff to install it though.
what exactly do i need (02 GT)
how much gear fluid
do i need friction modifier? etc. i need to include everything
how much gear fluid
Yes you will need a basic install kit, you will most likely need different shim combinations then your last setup. So I would get a gear, Install kit, Oil and Additive. That should take care of you. Let me know if we can help you out.
Jeff
Jeff
IF THE CAR HAS OVER 60k MILES, I SUGGEST THAT YOU GET THE KIT THAT INCLUDES THE AXLE SHAFT BEARINGS AND AXLE SHAFT SEALS. YOU HAVE TO REMOVE THEM ANYWAY WHEN CHANGING OUT GEARS, SO YOU MIGHT AS WELL REPLACE THEM WITH NEW ONES. 8.8" FRPP RING & PINION INSTALL KIT M-4210-C, 3 BOTTLES OF 75W-140 SYNTHEIC GEAR OIL, 4 OZ BOTTLE OF FRICTION MODIFIER, AND BLUE NUT THREAD LOCK.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
