2001 bullitt stalls when turning or coming to stop
The first thing that I can think of is the IAC (Idle Air Control). This little motor sits in the intake track- it will vary the idle speed AND compensate for the A/C system.
Check to make sure it's working properly and that it's clean.
Five months is plenty of time for it to become dirty again.
Try a couple of cans of spray throttle body or carb cleaner.You can stick the little red straw in between the IAC inlet and the rubber hose connecting it to the intake tube.You can use the butterfly to keep the engine running or have someone sit in the car and use the gas pedal.The straws aren't as tough as they used to be so A small nail stuck in beside the straw will keep the hose from smashing it shut.
Now warm the engine to operating temperature and spray away.As the IAC is cleaned the engine should start idleing better and as a bonus the intake tract will be cleaned.Don't mind the white smoke that'll come out the exhaust,It'll be real cool for the 4th of July holiday.If you set a check engine light just pull the battery cable to reset.
thanks
ok i have sprayed some cleaner but nothing just to day i turned on and starts and then shuts off so what else may u think may it be the injectors or bad gas or bad alternator the battery was replace about February but we dont drive this stang for a every day use just keep it in the garage use it may twice a month and had it for about a year and a half
bryan616fl
01-25-2019 09:07 PM
Calizic
08-28-2015 01:46 PM
jpplaw
08-22-2015 09:29 PM
