leaking antifreeze from passenger side of engine
Hello all, I have a 67 mustang and I noticed today as I was replacing the alternator and starter solenoide and I noticed that I started to over heat. I turned the car off and heard a hissing sound from the passenger side of the engine. I noticed that underneath the car I was leaking antifreeze. The bottom radiator hose was cool and the upper hose was hot. Any idea what would be causing this leak and what options I have to fix it?
Really hard to tell what the problem is.. how long did it run before started to heat up? What engine do you have? There are a couple places the coolant could be coming from. Check closely on your water pump and headgaskets though./
inyadreems
08-21-2015 09:10 AM
2000, 2005, 67, anti, antifreeze, break, engine, freeze, gt, leak, leaking, mustang, passengerside, period, underneath
