RPM reads 2 at a complete stop!
Old 07-05-2005, 03:12 PM
shieldsba
shieldsba's Avatar
Default RPM reads 2 at a complete stop!
Hello, I have a 95 Mustang GT.
When I come to a stop, I put the car in neutral and just have my foot on the break. But, the RPM still reads at 2 and it sounds like the car is running the engine very strongly (almost reving the engine). Usually in neutral the RPM reads between 0 and 1. It is very strange - any advice? Anyone have any more info on Auto Zone? Thanks!!!!
I recently had a coil that needed to be replaced. So I had it repaired, but now this problem appeared! Do you think when I had the coil problem fixed, this happened?
shieldsba is offline
Old 07-05-2005, 04:21 PM
stanglx2002
stanglx2002's Avatar
Default RE: RPM reads 2 at a complete stop!
clean the IAC
stanglx2002 is offline
Old 07-05-2005, 06:02 PM
white_snake
white_snake's Avatar
check your throttle postion sensor too. i just had to change mine today. it didnt rev that high but it reved when it shoulnt have.
white_snake is offline
Old 07-08-2005, 02:51 AM
razarr69
razarr69's Avatar
mine does that after im on the gas pretty hard, like where we race here theres a stop sign at the end n when i stop the idle is sumtimes stuck at 2100 or 1500 depending on how hard i went i usuallly jus punch on it once real fast n then itll slowly go down but if u acutally wanan fix it it prolly has sumthing to do wit tha iac.
razarr69 is offline
djbigskrilla
09-20-2022 01:04 AM
cardsrus1
19
09-15-2015 08:37 AM
FD725
08-23-2015 06:43 AM
FD725
08-11-2015 03:43 AM
Quick Reply: RPM reads 2 at a complete stop!
