Removing hood heat shield thingy
i was under the hood the either day and im going to remove my hood heat shield thing on the under side of the hood i see that there is some type of ground wire attached to it on back passenger side. im wondering if i can just remove this or should i bolt it to another ground point?
not sure how it is on the cobras, but on my 94 gt, that wire was to power the light under the hood. i dont think it would be an actual ground because the hood is fiberglass and you cant really ground stuff to fiberglass.
hmm well if its just the light then ill jus lose it (got flashlight in the car) well the under side of the mat has layer of metallic something on it like aluminum foil and the end of the wire thing is green so i figured ... thanks tho
ya ive heard that but also heard that people take it off with no problem aftermarket hoods dont have them so i figure it would be fine the only reason i want to take it off is because my belt broke (out of nowhere, not neglect) and ripped up part of the mat
jwog666
12-27-2021 08:09 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
