05-09 Wiring Diagram Needed.
Does anyone have a detailed wiring diagram for under the dash for an S197 05-09? They should be pretty much the same for those years I imagine. If you have one for an 09 that would be the best. Thanks....
The fuel pump driver module wire is at pin 12 of the PCM. It is light blue/red. The PCM power wire is at pin 37 of the PCM. It is brown/pink.
Thanks for the info. That works great.
