A/C clutch not kicking in
Old 07-18-2005, 08:34 PM
ghoste
ghoste's Avatar
Default A/C clutch not kicking in
Okay, after the installation of my gauges, I go out and drive the car around a bit, I get back home, park it.
Next morning, driving to work, I notice my A/C not working. I turn the hvac **** to a/c and max a/c. The clutch isnt even kicking in.
Ive checked #23 15A (A/C Clutch/Defogger Switch) fuse located under steering column, fine.
Checked all fuses in the engine bay (left hand side), fine.
A/C Clutches dont magically go out like this, It has to be electrical connection somewhere that might of
gotten unplugged, but I cannot find anything. I soldered the power wires for my gauges to the grey w/yellow stripe wire
directly under my steering column for gauge power.
Anybody have any ideas?
ghoste is offline
Old 07-18-2005, 10:34 PM
99saleen351r
99saleen351r's Avatar
Default RE: A/C clutch not kicking in
A/c clutches Do magicly go out like that.Start the car and jump a wire to the ac clutch if it doesnt turn on its bad.I'd bet thats what it is.Its a magnet and they dont go slowly they go all at once
Why would you solder on random wires and not just run it to the fuse box??
99saleen351r is offline
Old 07-18-2005, 10:52 PM
ghoste
ghoste's Avatar
ORIGINAL: 99saleen351r
Its not a random wire, it is the ignition wire ... and running wires to the fuse box is.. well you know.
Thank you for the advice
ghoste is offline
Thunderball
15
11-22-2015 11:49 PM
Explosive
10-02-2015 07:45 AM
Florida Regional Chapter
09-30-2015 08:04 PM
69Volunteer
09-30-2015 10:39 AM
junior04
09-28-2015 10:53 AM
Quick Reply: A/C clutch not kicking in
