MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   General Tech (https://mustangforums.com/forum/general-tech-6/)
-   -   My speedometer isn't working. (https://mustangforums.com/forum/general-tech/581194-my-speedometer-isnt-working.html)
DocHolliday Jan 11, 2010 05:32 PM
While in the process of replacing my stereo, in my 95 GT, with one I had in my other car some wires sparked. Turns out my old stereo was shorted out. now my speedometer isnt working. All other gauges work fine. What fuses control the speedometer? Also are all the fuses located under the hood or is there a cluster inside the cabin? A link to an online manual would be helpful. Thanks in advance.
Sonic_Stang Jan 11, 2010 06:14 PM
Same exact thing happened to me except my car wouldn't start after haha There is actually a smaller fuse panel under your steering wheel column, That's where I had to replace my fuse. If you go to google type in 1995 Mustang Fuse Diagram. That should point out which fuse to replace. You can also hit up AutoZone get a fuse kit for 10 bucks which will have a fuse tester. It's not fun but you can pull each fuse out and test it. Hope this helps you a little man Good Luck!
DocHolliday Jan 11, 2010 08:27 PM
Thank you man. I was going to check under there the other day but I ran out of time. Checked everywhere else hahahaha. Anyways. thanks Ill check it tomorrow after class.
DocHolliday Jan 11, 2010 09:40 PM
Ok so I replaced some burnt fuses and everything works now. Thanks. Mods please lock thread.
© 2026 MH Sub I, LLC dba Internet Brands
