| robrattstang |
Jan 23, 2010 12:40 PM |
daytime running lights won't go off
I have a 92 5.0 fox body, for the past 2 days when I turn off the car and remove key from ignition the drl's won't turn off, have to remove terminal from battery for now, as well the drl's won't turn off when applying e-brake when car is running or off. Have heard the switch in the e-brake console may be worn out or wire may be stripped and touching part of the framing creating a circuit. Wondering if disconnecting the drl from e-brake will fix problem or is there a fuse or module just for them ?
