New to forum. How to maintain my mustand
Hi, I have a 2006 mustang GT with over 90,000 miles on it. I am getting ready to take it in for service but wanted to know if anyone had any suggestions on how best to maintain it. Should I be using different spark plugs? What can I do to make sure I am taking the best care possible of my baby?
Wow, someone has been driving the wheels off that thing. If it is new to you, you will want them to do give it a good check over to see if any major service was done at 50k or 75k miles. Have them check the conditions of the plugs, flush the trans, check the coolant, change the oil & filter. For regular maintenance, just keep the oil fresh, the outside washed and the inside detailed and it will provide you with many more happy miles.
Also, is it bone stock, or have you done anything to it?
I was told spark plugs last 300K miles BUT I changed mine at 75K I used BOSCH Platinum. Also you can replace your plug WIRES. Start using full Synthetic oil, cost more but you know it wont break down after 2000K miles. I use Valvoline Full Synthetic.
Change your air filter as often as it needs it , normally every 4 months for me. I dont drive a lot. I took my radiator reservoir off one day and washed it out with the hose, lots of gunk in there. Be sure you wash under the car lots after the roads are salted for winter.
SEAFOAM is sold at auto zone, its a one in all miracle can. You can use it to clean your fuel line (add to gas tank) or clean your cars inatke (Pour into IAC valve) You'll see white junk come out your exhaust for a min, clean until no more white smoke.
yeah same stuff
i like mobil1 "hi mileage" synthetic oil, or mobil1 "extended life" 10w30 either way
you will virtually stop engine wear with a switch to synthetic, add 10% mileage and about 2% hp... thats no lie
change intervals bump out to about 5k over 3k and if you go to walmart you can get a 5qt jug for $22 or so
keep it clean, including the underbody and spots that hide grime or salt like the the wheel wells and places where stuff will accumulate
wax it often, and drive it like hell
Guy that I knew and worked on my 240sx was telling me in states like Florida where the sun is more intense, I should use polish rather then wax. I take his work, he normally restores classic cars.
I live in Ky now and use NXT1 wax or what ever its called, only use wax twice a year , over wax change remove clear coat.
09-24-2015 09:18 PM
