Stall Converter opinion's????
I need help! I need a stall converter but don't know what to go with. I have a 331 stroker. I've built it myself, my 1st engine. Hoping to get between 400 and 500 hp. It has eagle cast steel crank, eagle sir- I beam rods, Keith Black forged 11 cc flat top piston, tfs 2 cam 2,500 -6,oooo is power range, pro comp alum heads, weiand stealth intake, amd 750 speed demon elec choke and vac sec. And a C4 built with transgo shift kit. 17 in 3 star rims with 245/45 and stock rear end in a 87 gt. Should I have one built for $225 or buy one off the shelf from somewhere
What rear gear ratio? Are you wanting to make it a pure drag car or what?
factory gears for now! will end uo with 3.73 .It'll just be a dd mainly and track every once in awhile
Originally Posted by crob369420
(Post 6880991)
i'm also assuming your using an AOD but first thing, i promise you if you go less than 3000 you'll be really pi$$ed, 3500+ is a must i only hear good things about precision, and lentech fyi , i used a tci 2200 and it felt like stock in my '90 AOD car |
sorry it's st pattys day and ive been on the juice since 7:30
yeah much cheaper for a c4...and more options for manufacturers too..... but i still lke those 2 best |
was going to have one built from a place B&I close to where I live. How bout ptc they said 375 heard any good things about them
like bob said, no such thing as a good converter under $500. fwiw, i paid $800 for mine. if you go off the shelf, get a 4000rpm stall. they never stall as high as they are rated for.
bought a 3000-3500 from ptc
| All times are GMT -5. The time now is 05:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
