Fianl Build list!!! let me know what you think
This is the build list I have generated for the '99 545 drag/show car. Haven't started yet. Whats everyone think? Open for suggestions. Didn't give every part a specific brand yet...
’99 mustang
Black with black carbon fiber hood (3 or 4 inch cowl)/black rear windshield blinds/black between tail lights/black front and rear spoilers/black headlights/black taillights /cobra style front and rear bumper (Blackout)
Engine Specs
Ford 460 Big Block
Stroke and bore to a 545
Bore 0.030” oversize (4.390)
Original 460 stroke=3.85”
Stroke 545=4.50” (.65 increase)
High flow 72cc kaase P-51 heads Port and Polish with complete stud kit, solid roller cam, steel valves, springs, and rockers
P51 Cylinder
Head Specs
Intake runner volume: 310 cc
Exhaust port volume: 145 cc
Intake valve diameter: 2.250 inches
Exhaust valve diameter: 1.760 inches
Valve length (int./exh.): 5.245/5.080
Intake valve angle: 8.3 degrees
Intake valve cant: 4.7 degrees
Exhaust valve angle: 4.0 degrees
Exhaust valve cant: 3.2 degrees
Spring diameter: 1.550 inches
Valve guide: 11/32 inch
(All forged internals)
Balanced Cast steel Crank with 4.50” stroke
.030 oversized forged flat top pistons
13.7:1 Piston Compression
6.700” Center to Center Length forged connecting rods
.510 lift solid roller cam 280 duration
High performance bearings
Electric water pump/Aeromotive fuel system with tank sump/fan
Oil pressure tune to 70psi
MSD Ignition
Single Plane 1500-6500 RPM Power band Manifold
Edelbrock 750cfm carburetor
Trans
Ford C6 Trans with trans brake (contains manual valve body)
7qt moroso oil pan
High performance clutch/pressure plates/Springs
3000 Stall Torque Converter
SFI bellhousing like Lakewood
SFI flywheel and balancer
35 spline axles 9" axles with Detroit locker rear end 3.73 or 4.11 gears
Aluminum Drive shaft
Drive Shaft loops
Suspension and Tires
Drag radials or slicks…not sure yet
Performance calipers/pads/rotors (Wilwood disc brakes front and rear)
UPR manual brake kit
Performance Suspension…
Tubular a-arms
300lb coil-overs
Fox body 460 swap mounts
Fox body 460 swap headers
Hurst roll control
Manual rack
Sway bar bushings
Sway bar end links
1'' front sway bar (black powder coated)
1 set strut rod bushings
1 pair of KYB self-adjusting gas shocks
2 inner tie rods
2 outer tie rods
2 tie rod-adjusting sleeves
Four-link rear end like TCP G-Bar
Sub-frame connectors with cross brace piece
strut tower brace
94/95 UPR k member
+More
Gut interior
8-point roll cage welded through the floor to the frame.
Battery and racing fuel cell in trunk
’99 mustang
Engine Specs
Ford 460 Big Block
P51 Cylinder
Head Specs
MSD Ignition
Trans
7qt moroso oil pan
Drive Shaft loops
Tubular a-arms
300lb coil-overs
Hurst roll control
Manual rack
Sway bar bushings
Sway bar end links
2 inner tie rods
2 outer tie rods
strut tower brace
94/95 UPR k member
+More
Gut interior
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
09-16-2015 07:53 PM
