Sponsored by:
Sponsored by: DashLynx
v6 2011 mustang higher octane gas
Old 07-04-2010, 10:52 PM
keerf
keerf's Avatar
Default v6 2011 mustang higher octane gas
Hi All,
I have what I'm sure is going to sound like a dumb question.
I just bought a new 2011 v6 mustang a few weeks ago. For my first two fillups, I've put in plus grade fuel (aka 89 octane). I know my car is rated for 87 and it says so to use that in the manual.
Being that this is the break in period of the car, is using a higher octane fuel going to hurt my car? Should I just revert back to 87 and not worry about it. I seem to read conflicting reports here onthe web from various forums that higher grade octane can or won't hurt your engine and performance.
Any help would be great.
Thanks all!
keerf is offline
Old 07-05-2010, 01:05 AM
MU71L4710N
MU71L4710N's Avatar
waste of money unless your tuned for higher octane gas...
wikipedia fuel octane
MU71L4710N is offline
Old 07-05-2010, 03:06 AM
Snakebite64
Snakebite64's Avatar
Wasting money is never a great idea
Snakebite64 is offline
Old 07-05-2010, 08:13 AM
GreyStang
GreyStang's Avatar
All those conflicting reports are probably coming from people blindly pushing the myth that "the higher the octane the better" It isn't true.. just use the octane recommended in your owners manual, UNLESS you've modded your car then it can change.
GreyStang is offline
Old 07-05-2010, 08:59 AM
keerf
keerf's Avatar
Ok, I will switch to 87.
But I guess my original question kind of remains un-answered. Using the higher octane, it won't damage anything though correct? Cause I've only done 2 fillups so far, and used higher octane on both those fillups.
Thanks for all the help.
keerf is offline
Old 07-05-2010, 09:58 AM
GreyStang
GreyStang's Avatar
Using WAAAY higher octane than required can & will harm your (stock) engine. But 89 is close enough to 87 that it probably won't matter,, you're just wasting money for no advantage.
Old 07-07-2010, 11:38 AM
mestit3
mestit3's Avatar
yepp.
mestit3 is offline
Old 07-10-2010, 11:02 PM
dastangman
dastangman's Avatar
To add to people who have posted, rather than just agreeing, I wanted to state why it's a waste to buy higher octane. I use a higher octane gas in my daily driver all the time, haha...in Iowa our Super Unleaded 89 is about 10 cents cheaper than the regular 87. That's because it has ethanol in it and has been subsidized by our government.
A.) Yes, this is the break in period, and refer to your owners manual for details, but it's really the oil that's going to affect the break in period. Most cars these days are basically already to go for the most part, some even built to use synthetic oil for the break-in, but you'll have to check. Anyways, to my knowledge, your fuel (unless again your tuned for something specific) isn't going to have an affect on your engine break in.
B.) And here's why...octane rating is only a "measurement" of a resistance to detonation. A car with a high compression ratio, advanced timing, superchargers or a variety of other stuff, usually in the performance realm, will require premium because the chance of detonation and blowing a piston is much higher. And even if a car could use regular, especially those with knock sensors, a lot of manufacturers probably just stamp on to use premium as an insurance of sorts in case something could go wrong.
So, yes there's no added cleaning benefit, better gas mileage benefit, and the only performance benefit is that you're able to have more potential without having detonation. In other words, with premium you can have superchargers, higher compression, etc and because of this you can have better performance. There's a good chance that someone who says their car performs a lot better with premium is probably only mentally thinking this. The only thing I could see is a car that's been running regular instead of premium and that has knock sensors, may have been electronically cutting back timing and reducing performance, so that when they do fill up with premium they are getting a performance boost, but in that sense, they're basically tuned from the factory for it and by using premium you aren't improving performance, but rather by not using premium you'd be hurting performance.
Anyways, you're wasting nearly 13 cents a gallon around these parts if you're using premium.
dastangman is offline
Old 07-11-2010, 03:49 PM
bigjohnstud4200
bigjohnstud4200's Avatar
on a different note, how is the new v6? have you raced any older generation stock gt's?
bigjohnstud4200 is offline
Old 07-12-2010, 12:50 PM
CopNaStang
CopNaStang's Avatar
The new GT's lose 11hp if premium is not used, but it may call for premium.
CopNaStang is offline
Quick Reply: v6 2011 mustang higher octane gas
