car stalls when ac is turned on
Everytime i turn my a/c on my car stalls and sometimes dies. I haven't tried anything to fix it yet because i wanted to find out exactly what it was before i start tearing stuff apart. The engines runs fine when its off but as soon as i turn it on it starts running terrible. its a 92 5.0 and the a/c worked fine when i got it. If anybody has had the same problem let me now because its hot as hell in texas
RE: car stalls when ac is turned on
Thats not the problem if no ones worked on it. When you turn on the A/C the computer is soupose to hold the rpm steady as the A/C copressor loads up. When you turn the A/C do the Rpms drop and then come back up? Are do the rmps stay low the wholw time A/C is on? Could be a Vaccum leak or carbon build up causeing a slow responce to load at low RPM's
Are you sure the compressor isnt seized??The car should automaticly idle a little higher with the ac on
Edit: the car will run fine without the ac on because the clutch on the ac doesnt engage till you turn on the ac and then it will try to turn the compressor and willl stall out if its siezed
Ther is a sensor on the hi side of the AC. When the compressor turn on this sensor send a signal to the computor to increase the idle. If luck is on your side the connector came off or you have corrosion. If not you'll have to replace the sensor.
ORIGINAL: 99saleen351r
it could be the IAC too...(idle air charge).........cuz mines bad, and when i turn my a/c on, the car wants to die, so, it could be that, unless youre not gettin a check engine light.....if youre not gettin a check engine light, then its NOT the iac.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
