Welded together aftermarket oil pans
Old 02-24-2011, 03:37 PM
4fords
4fords's Avatar
Default Welded together aftermarket oil pans
One of my cars developed a small crack in the bottom of the oil pan during the trip last week to San Diego and I had to have the thing welded up for the return trip to AZ. Without going into a lot of detail it could have easily trashed the motor.
The pan was one of the Melodon with the welded in pieces to extrend it out on the sides.
I had actually considered not using it during the motor build because all the welds looked like a weak link in the thing from the start.
No dent No hit it just cracked next to a weld from vibration and the weight of the oil banging around. Had less than 5 thousand miles on the motor and pan.
Hind sight being 20 20, anyone else have experience with the Melodon fabricated welded together oil pans (issues)?
4fords is offline
Old 02-27-2011, 07:17 AM
uedlose
uedlose's Avatar
I run Moroso pans and have never had any issues with mine is the same way with all the welds.
uedlose is offline
Old 02-27-2011, 02:10 PM
67mustang302
67mustang302's Avatar
There's no way you could tell a weld was a weak link unless you have x-ray vision or it's obviously contaminated. Regardless, you should contact them and have them replace it. Occasionally a defective part goes out the door.
Does your engine vibrate a lot?
67mustang302 is offline
Old 02-28-2011, 06:39 PM
4fords
4fords's Avatar
No idea why it cracked the eng has always ran without any vibration its a 70 429 cobra jet motor that has been ballanced with less than 5000 miles on the motor.
I talked to the one of the shop guys that I had do the work since I had no way to do it he went ahead and rewelded the pan inside at the original weld locations. Like I said we both looked it over no dings from rocks dents etc.
4fords is offline
Old 02-28-2011, 07:59 PM
67mustang302
Did you torque the pan down with the torque sequence, or just bolt it on? I suppose it's possible if it were just tightened down that it could have stressed from thermal expansion and cracked.
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
wraith777
09-28-2015 10:49 AM
09-24-2015 09:18 PM
Quick Reply: Welded together aftermarket oil pans
