prombles due to cold air intake?
I just bought a 02 gt 5sp about 6 months ago. It already had a cold air intake on it and upgraded exhaust. I took it in the shop because it pings on reg unleaded, so I have to put in super. The shop said it is running lean due to the cold air intake and suggested putting it back to stock. A freind suggested getting a stronger fule pump? In addition to the pingging, once in a while, it takes a few extra cranks to get it started after it is warmed up and letting it sit for a few minutes, like getting gas. But if I hold the pedal down just a little, it starts right up. The shop said thats due to the cold air intake too. Should I remove the cold air intake? If I don't remove it, would I risk causing any damage in the future to the engine? I love the way my stang sounds and would removing the cold air intake affect the sound of the exhaust?
Thanks for you help
[sm=feedback.gif]
Thanks for you help
[sm=feedback.gif]
RE: prombles due to cold air intake?
Yea, you running lean. Correct that using a chip.
Is it really a cold air intake, or you goulping hot air from underneath your hood? If it's a nice looking hot air intake, then I'd dump it.
ORIGINAL: nurstang
Thanks for you help
[sm=feedback.gif]
Thanks for you help
[sm=feedback.gif]
I think it would be a good idea to get it on a Dyno to see what all your dealing with.
As little crap as changing or gutting your stock air box can lead to lean condition. This is due to increased velosity throught the MAF sensor, combine that with gulping hot air and you have a very serious problem.
The cold air intake goes into the fender wall and is not sucking in hot air. The car is currently at the dealer getting serviced. They said that they did a road test and checked it out and it is running lean due to the CAI. Could California Emissions have anything to due with it? Anyone know of a good shop I can take it to in the LA/ San Bernardino area.
Thank you everyone for your help
[sm=thanx.gif]
[sm=thanx.gif]
The same thing has happend to my 03 Mustang Gt.I put a CAI on, now it lags majorly.It used to kick down hard and pull secong gear chirps with my stock airbox on.Th eonly mod I have is Dynomax mufflers. I think either taking it off, getting a chip, or reseting the computer may be the only way to fix this. Some combos work and some don't, its as simple as that. You would think that it would work, it works for alot of people, but not every car is the same.
[align=left] [/align]
If it has a bend in it lose it. The bend causes the MAF to get poor readings and could result in you being lean. Or it could just be that you need to clean or replace your MAF because it is clogged.
09-01-2015 08:16 PM
