brake pedal spongy after pad swap
just changed out the front break pads on the car. Couldnt turn the rotors due to they are drilled/slotted. and i took the car down the road a lilttle and the brake pedal is real spongy. never opened the lines, so i know its not air. Should i just put some miles on em to see if they settle?
ya i just got back from seeing if i couldnt settle them in, did about 5 60mph to 0 stops,then some regular city driving. definitely feeling better. They were smoking a lil after the 60-0 stops tho..
After doing the brake job, did you pump the brakes a bunch of times before starting the car? You need to push the fluid back into the system from the master cylinder etc.
Also, if you haven't flushed your brake lines in a while now is a perfect time to do it. Brake fluid should be replaced every 2 years or so. Over time it will get water in it due to condensation and will effect your braking performance. Its the nature of the type of brake fluid in our vehicles. You would be surprised at the improvement in braking performance you get from a simple brake flush and bleed... Good luck...
I assume you got the correct pads, but every now and then, the people that sell you the pads screw up and one or more of your brakes have the wrong thickness of pads in them before they engage.Heck, even the dealership could have sold you the wrong pads, that is if you bought from the dealership.
I am guessing the wrong thickness of pads as a possible reason for sponginess. But I could be wrong.
Also, just because you did not open the brake lines or the master cylinder does not guaranty that air got in some how. The car is old, and when you compressed the caliper pistons in so you can slip in new pads, the pressure could have caused the brake lines to spring a leak somewhere.
You should inspect the brake lines for any leaks, check the pistons and the master cylinder too.
Good luck...
Bad things can happen to cars with ABS when you push the caliper cup back in and force fluid back into the master cyl. The proper way is to wrap a rag around the hose and pinch it closed with a pair of locking pliers, then open the bleeder and push the cup back in letting the excess fluid come out the bleeder instead of being forced back up to to the MC.
Not to mention that keeping the bleeder open while you compress the piston would allow air to get back into the system unless you have the super-human ability to compress the piston with one push.
Also, you don't want to pinch off the hose. You run the very real risk of damaging it. Hoses aren't meant to be crimped/pinched, especially as they get older
