95 mustang trouble starting after warm
i have a 95 mustang it starts up fine when cold but if i go to start it after its warm i need to pump the gas could it be the fuel pump? i always have gas in my car not sure what it could be
Pumping the gas does absolutely nothing on a fuel injected car. On older carbureted cars, pumping the gas pedal would squirt a little extra gas into the motor.
I'd try this, cycle your key on and off a couple times before trying to start it. Listen to hear your fuel pump prime each time. On the 4th time, see if it starts better. You may have a bad injector allowing fuel pressure to bleed off, or a bad fuel regulator.
Usually when a pump goes bad, they just stop working all together.
And welcome to the forum, hope we can help you out. Post back to let us know if this helps.
Design1795
01-24-2017 10:38 PM
panic
08-25-2015 09:34 AM
Design1795
08-24-2015 04:41 PM
