2006 mustang gt pulls to the right when using summer wheels?
#21
It's not the alignment. It's the tires. You need to take the 2 front tires that are on the front of the car unmount them and swap them from side to side. They call this radial pull and it's not that uncommon. I just got a brand new set of nittos awhile back and they had to be swapped from side to side.
Sometimes when you do have radial pull driving the vehicle will cause it to cure itself. However it doesn't always and it's annoying.
#22
ahh, so is this more common with directional tires?
so basically i need to take my front right wheel and switch it with front left, even though it will be in wrong direction?
#24
I would assume running the tires in the wrong direction will make them pull weird. The radials have steel wrapping in the tire and swapping directions between sides will make then do funny things. My wife's car had it and my cat had it. It's not uncommon.
#25
No. Take it to the shop you bought the tires at. Tell them the problem. Tell them to remove the front wheels and tires and dismount the tires and swap to the other wheels. If they are directional this is what your will have to do.
#26
its so stupid, why do manufacturers even bother making directional tires when they do nothing but cause problems?? everybody should only make asymmetrical tires. it would suck so much if ya had staggered setup AND directional tires, you would pretty much need to replace each tire on its own every time something went wrong!!
#27
Directional tires do serve a purpose especially in wet weather. Tires pump out water in the rain. Imagine running a pump backwards. Just make sure when dismounting and remounting tires, they stay on the same side.
#28
Having performance like I do comes at some price. And it is a pita at times.
AFMarksman
09-17-2018 03:08 PM
DerekShiekhi
03-03-2016 04:40 AM
